TDR Issue 64 - May/June/July 2009
TDR Issue 63 - Feb/March/April 2009
TDR Issue 65 - August/September/October 2009
TDRadmin
Staff Member
[RAW]#ad
<table style="color: rgb(0, 0, 0); height: 101px;" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr>
<td style="vertical-align: top;">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">ARTICLES | Sold Out </span></font></td>
</tr>
<tr>
<td style="font-weight: bold; text-align: left;">
<font face="Arial, Helvetica, sans-serif" size="2">Member2Member</font><font style="font-weight: normal;" face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><span style="font-family: Arial;"><span style="font-weight: normal;"></span></span><span style="font-weight: bold; font-family: Arial;"><span style="font-weight: normal;"></span></span><span style="font-size: 10pt;"><span style="font-weight: normal;"></span></span><span style="font-size: 10pt;"><span style="font-weight: normal;"></span></span><font face="Arial, Helvetica, sans-serif" size="2"><br/><span style="font-weight: normal;"><span style="font-weight: bold;"></span></span></font><span style="font-family: Arial;"><span style="font-weight: normal;"></span></span><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">Steering Improvements - Part 2/Turbo Air Guide - Tag 3 Update</span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">10 Back</span><br/><span style="font-weight: normal;">Issue 24, May/June/July 1999</span></font></td>
</tr>
<tr>
<td style="text-align: left;">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">First Generation</span><br/><span style="font-weight: normal;">Replace the Fuel Filter/Leak on Fuel Filter Housing/Heater Valve/Lower Radiator Hose/Loose Steering/Spring Hanger Bushings/Front Rotor Disc Wear/injection Pump Wear/Killer Dowel Pin</span></font></td>
</tr>
<tr>
<p><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">12-Valve Engines<br/></span>Recurring Diagnostic Code P1389/Front Crankshaft Seal and Wear Ring/Automatic Transmission Shifts Erratically/Gauges and Accessories Inoperative/Installing Plungers and Barrels in the P7100 Injection Pump/Setting Injection Timing When Replacing Pump/How to Make 600 Horsepower/Removing Camshaft Drive Gear</font></p></td>
</tr>
<tr>
<td style="text-align: left;" valign="center">
<p><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">24-Valve Engines<br/></span>Defective Fuel Line Check Valve/Engine Block Heater/Transmission Fluid Loss/Fuel Leak at Fuel Filter/Engine Oil Pressure Sending Unit/Turbo Upgrade Advice/Selecting a Head Gasket/Tabbing the Killer Dowel Pin/Uneven Braking</font></p></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">5.9 HP CR</span></font><br/><span style="font-size: 10pt; font-family: Arial;"></span><span style="font-size: 10pt;"></span><span style="font-family: Arial;"></span><font face="Arial, Helvetica, sans-serif" size="2">Oil Leaking From Intercooler Hose/Slow to Shift Transmission/Adjusting the Doors/Unusual Starting Behavior/Finding the Bad Injector/Replacing Injectors?/Better Injectors?/Preventive Maintenance?/Help Needed for Installing Twin Turbos/Erratic Rail Pressure</font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">6.7 HP CR<br/></span>Wiring Trailer Receptacle/New Truck Questions/Cycle the Key for Codes Feature/Check Engine Light/engine Hesitation-Stutter/CCV Filter/6.7 HPCR Basics-Changing the CCV Filter/6.7 HPCR Oil Change Data/TSB Releases on the 6.7 Engine/Future ECM Complexity and Current Diagnostic Trouble Codes/6.7-Liter Fuel Filter Follies</font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Technical Topics<br/></span></font><font face="Arial, Helvetica, sans-serif" size="2">Media Gibberish/Fuel and Oil Additives</font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Cummins' Column<br/></span>6.7-Liter Ask the Engineer</font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">TDReview<br/></span>2010 Dodge Ram 25500/3500 Heavy Duty and 3500/4500/5500 Chassis Cab Introduction</font></td>
</tr>
</tbody>
</table>
<br style="color: rgb(0, 0, 0);">[/RAW]
