TDR Issue 70 - November/December/January 2010-2011
TDR Issue 69 - August/September/October 2010
TDR Issue 71 - February/March/April 2011
TDRadmin
Staff Member
[RAW]#ad
<table style="height: 101px; color: rgb(0, 0, 0);" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="vertical-align: top;">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">ARTICLES | Sold Out</span></font></td>
</tr>
<tr align="left">
<td style="font-weight: bold;">
<font face="Arial,
Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Tailgating</span></font><br/><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">Modifications That Disappoint</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"><br/></span></font></td>
</tr>
<tr align="left">
<font face="Arial,
Helvetica, sans-serif" size="2"><span style="font-weight: bold;">10 Back</span></font><br/><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">Issue 30, November/December/January 2000-2001 (Industry News</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •Installation of Accessories</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Service</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Problem Areas)<br/></span></font></td>
</tr>
<tr>
<font face="Arial,
Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Member2Member</span></font><br/><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">Smog Check Update</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • CARB Goes to the BAR</span></font><font face="Arial,
Helvetica, sans-serif" size="2"><span style="font-weight: bold;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font></td>
</tr>
<tr align="left">
<td>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">First Generation</span><br/><span style="font-weight: normal;">Erratic Fuel Gauge</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Voltage Gauge</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Transmission Cooler Check Valve</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Gear Case Bolts Behind Cam Gear</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Erratic Speedometer</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Injection Pump Drive Gear</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Clutches for First Generation Engines<br/></span></font></td>
</tr>
<tr align="left">
<td>
<p><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">12-Valve Engines<br/></span>Another NV4500 to G56</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Leaking Fuel at the Injection Pump</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Intermittent Start Problem</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Cruise Control</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Clutch Release Problem</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Hot Weather Problem</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Three Common Problems, Again</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Torque Plates and Timing</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Shift Tower for NV4500</span></font><font face="Arial, Helvetica, sans-serif" size="2"></font></p></td>
</tr>
<tr align="left">
<td valign="center">
<p><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">24-Valve Engines<br/></span>Slight Surge When Shifting Into Overdrive</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Front Axle Leak</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Front Axle Not Disengaging After Using Four-Wheel Drive</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Air Conditioner Blows Cold Air Only on Defrost</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • More Torque Converter Lock/Unlock</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Performance Modifications</span></font><font face="Arial, Helvetica,
sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"> </font></p></td>
</tr>
<tr align="left">
<td>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">5.9 HP CR</span></font><br/><span style="font-family: arial; font-size: 10pt;"></span><span style="font-size: 10pt;"></span><span style="font-family: arial;"></span><font face="Arial, Helvetica, sans-serif" size="2">Complete Transmission Fluid Change</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Transmission Fluid Leak&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Lift Pump Disassembly</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Engine Power Drops Off Above 50% Throttle</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • American Axle Limited-Slip</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Lots of Smoke, No Power</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Engine Cuts Out, Puff of Smoke</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Valve Lash Settings</span></font><font face="Arial, Helvetica,
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">6.7 HP CR</span></font><br/><span style="font-family: arial; font-size: 10pt;"></span><span style="font-size: 10pt;"></span><span style="font-family: arial;"></span><font face="Arial, Helvetica, sans-serif" size="2">High Coolant and Exhaust Gas Temperature</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Engine Cooling Fan Noise</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Black Fuel Filter</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Fourth Generation</span></font><br/>
<span style="font-family: arial; font-size: 10pt;"></span><span style="font-size: 10pt;"></span><span style="font-family: arial;"></span><font face="Arial, Helvetica, sans-serif" size="2">Fourth Gen Noise Evaluation</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Headlight Removal Tip</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Towing: Old Versus New</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • 4th Generation Overall Feedback</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Fumoto Finger Touch Oil Drain Valve</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Backup Camera</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Technical Topics</span></font><br/><font face="Arial, Helvetica, sans-serif" size="2">Holset HE351 Variable Geometry Turbine</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><br/><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">TDResource</span></font><br/>
<font face="Arial, Helvetica, sans-serif" size="2">This Year's Technical Service Bulletins</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Motor Minded</span></font><br/>
<font face="Arial, Helvetica, sans-serif" size="2">Changing Gears (Understanding Mechanical Empathy)<br/></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Idle Clatter</span></font><br/>
<a href="https://www.turbodieselregister.com/tdrarticles/tdrarticle70_IdleClatter.html"><font face="Arial, Helvetica, sans-serif" size="2">Equipping My New 2010 Truck</font></a><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Noise and Ride Comparison to a '07.5 Truck<br/></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">Have Ram, Will Travel</span></font><br/>
<font face="Arial, Helvetica, sans-serif" size="2">Change and Selecting an Aftermarket Turbocharger</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • Transfer Flow Fuel Tanks</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • A Visiti to Mag-Hytec</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • South Bend Double Disc Clutch<br/></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">TDRV</span></font><br/>
<font face="Arial, Helvetica, sans-serif" size="2">The Economy</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; "Free" Camping</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; The True Costs of Camping</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; Brake Controller Failure</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; Transmission Temperature</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"></span></font></td>
</tr>
<tr>
<font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: bold;">From The Shop Floor</span></font><br/>
<font face="Arial, Helvetica, sans-serif" size="2">Pre-Owned Purchase</font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> • 2010-2011 Steering/Suspension Changes</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; '98.5-'02 Gremlins</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; FASS Filter Availability</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;">&nbsp;</span></font><font face="Arial, Helvetica, sans-serif" size="2"><span style="font-weight: normal;"> •&nbsp; Second Generation Transmission Cooler Leaks<br/></span></font></td>
</tr>
</tbody>
</table>
<br style="color: rgb(0, 0, 0);">[/RAW]
