TDR Issue 76 - May/June/July 2012
2006 Dodge 2500 5.9
2007 Dodge Ram 2500 4x4 CCLB with Auto
<table style="HEIGHT:101px;COLOR:rgb(0,0,0)" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="VERTICAL-ALIGN:top">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="FONT-WEIGHT:bold">ARTICLES | Sold Out</a</font></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">10 Back</span><br/>Issue 36 Review - May/June/July 2002 • Industry News - Third Generation 2500 and 3500 Truck Revealed • Feature Articles - Oil Filters, Again • Topics of Interest - Is Premium Diesel Fuel Worth the Premium Price?<br/></span></td>
</tr>
<tr>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Member2Member</span><br/>What Do You Do About the Fuel Transfer Pump on Your '03-newer Truck?</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">First Generation</span><br/>Adding Extra Oil to a Getrag Transmission? • Replacement Cab Carpet • Intermittent Speedometer Reads Fast • NV4500 Replacement • No Cold Start • VE or P-Pump and Which Camshaft?<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">12-Valve Engines</span><br/>Four-Wheel Drive Vacuum Leak • Replace Brake Master Cylinder • Normal Vacuum at Vacuum Pump • IAT Sensor • No Overdrive and No Tach • Camshaft Specifications • NV4500 Lubricant</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">24-Valve Engines</span><br/>Fuel Leak • Oil Pan Gasket • No Gauge Cluster, No Start • VP44 Injection Pump and Tappet Cover Replacement • Lift Pump Won't Run When Key Is Turned On</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">5.9 HP CR</span><br/>OD Off/Transmission Temperature Warning Light Flash • Hard To Shift My NV5600 Into Reverse • Crankshaft Position Sensor Problems • Battery Terminal Corrosion • Torque Converter Coolant Line • Varying Engine Idle Speeds</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Power Steering Pump Fitment<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">6.7 HP CR</span><br/>Fuel Filter Questions • Exhaust Brake Squeal • Changing G56 Lubricant</span></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Fourth Generation</span><br/>Service 4-Wheel Drive Light On • Engine/Transmission Lurch At Start Up • Power Steering Problem • Exhaust Brake • Diesel Exhaust Smell In The Cab • Change The Fuel Filter On A '10?</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • No Left Side Headlights<br/></span></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Your Story</span><br/><a href="https://www.turbodieselregister.com/tdrarticles/tdrarticle75_YourStory.html"></a>Issue 73 Follow-Up - Under The Hood (2010 Ram ST)</span></td>
</tr>
<tr>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Technical Topics</span><br/>Lube Oils - Version 2012<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Blowin' In The Wind</span><br/>Diesel Fuel Versus Gasoline - Again<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDReview</span><br/>Some Gotta Win - 3500 Evaluation (Dodge- Chevrolet - Ford)</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Motor Minded</span><br/>Self Defense and Customer Service<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Have Ram, Will Travel</span><br/>Changing The VE Injection Pump<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Back In The Saddle</span><br/>Second Generation Steering Woes</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Pacbarke Installation</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Engine Maintenance </span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt">• FASS Fuel Pumps</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • ATS Transmission Pan/Differential Cover</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • New 12-Valve Injectors</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Timing The Engine</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • The Vibration Damper</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Intercoooler Boots</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Clearance Lights<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDRV</span><br/>Tampa RV Supershow • Fifth Wheel Wiring Harness and Receptacle • No Power At Trailer Receptacle B+ Pin&nbsp; • Selecting Trailer Tires • First Tow With My "3500 Max Tow" Package</span></td>
</tr>
<tr align="left">
<td br="" shop="" the="" from="">
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">From The Shop Floor</span><br/>Remove The Cyliner Head<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Exhaust Note by Kevin Cameron</span><br/>Piston Evolution<br/></span></td>
</tr>
</tbody>
</table>
<br style="COLOR:rgb(0,0,0)">
no download link was ever sent out for this one and several others. what is the point of prossessing back issues if they are not made downloadable to members that have already paid for the issue in the first place. wow just discovered i cant even read it online. i repeat what is the point!
