TDR Issue 76 - May/June/July 2012
TDR Issue 74 - November/December/January 2011-2012
TDR Issue 78 - November/December/January 2012-2013
TDRadmin
Staff Member
[RAW]#ad
<table style="HEIGHT:101px;COLOR:rgb(0,0,0)" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="VERTICAL-ALIGN:top">
<font face="Arial, Helvetica, sans-serif" size="2"><span style="FONT-WEIGHT:bold">ARTICLES | Sold Out</a</font></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">10 Back</span><br/>Issue 36 Review - May/June/July 2002 • Industry News - Third Generation 2500 and 3500 Truck Revealed • Feature Articles - Oil Filters, Again • Topics of Interest - Is Premium Diesel Fuel Worth the Premium Price?<br/></span></td>
</tr>
<tr>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Member2Member</span><br/>What Do You Do About the Fuel Transfer Pump on Your '03-newer Truck?</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">First Generation</span><br/>Adding Extra Oil to a Getrag Transmission? • Replacement Cab Carpet • Intermittent Speedometer Reads Fast • NV4500 Replacement • No Cold Start • VE or P-Pump and Which Camshaft?<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">12-Valve Engines</span><br/>Four-Wheel Drive Vacuum Leak • Replace Brake Master Cylinder • Normal Vacuum at Vacuum Pump • IAT Sensor • No Overdrive and No Tach • Camshaft Specifications • NV4500 Lubricant</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">24-Valve Engines</span><br/>Fuel Leak • Oil Pan Gasket • No Gauge Cluster, No Start • VP44 Injection Pump and Tappet Cover Replacement • Lift Pump Won't Run When Key Is Turned On</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">5.9 HP CR</span><br/>OD Off/Transmission Temperature Warning Light Flash • Hard To Shift My NV5600 Into Reverse • Crankshaft Position Sensor Problems • Battery Terminal Corrosion • Torque Converter Coolant Line • Varying Engine Idle Speeds</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Power Steering Pump Fitment<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">6.7 HP CR</span><br/>Fuel Filter Questions • Exhaust Brake Squeal • Changing G56 Lubricant</span></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Fourth Generation</span><br/>Service 4-Wheel Drive Light On • Engine/Transmission Lurch At Start Up • Power Steering Problem • Exhaust Brake • Diesel Exhaust Smell In The Cab • Change The Fuel Filter On A '10?</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • No Left Side Headlights<br/></span></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Your Story</span><br/><a href="https://www.turbodieselregister.com/tdrarticles/tdrarticle75_YourStory.html"></a>Issue 73 Follow-Up - Under The Hood (2010 Ram ST)</span></td>
</tr>
<tr>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Technical Topics</span><br/>Lube Oils - Version 2012<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Blowin' In The Wind</span><br/>Diesel Fuel Versus Gasoline - Again<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDReview</span><br/>Some Gotta Win - 3500 Evaluation (Dodge- Chevrolet - Ford)</span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Motor Minded</span><br/>Self Defense and Customer Service<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Have Ram, Will Travel</span><br/>Changing The VE Injection Pump<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Back In The Saddle</span><br/>Second Generation Steering Woes</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Pacbarke Installation</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Engine Maintenance </span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt">• FASS Fuel Pumps</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • ATS Transmission Pan/Differential Cover</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • New 12-Valve Injectors</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Timing The Engine</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • The Vibration Damper</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Intercoooler Boots</span><span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"> • Clearance Lights<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDRV</span><br/>Tampa RV Supershow • Fifth Wheel Wiring Harness and Receptacle • No Power At Trailer Receptacle B+ Pin&nbsp; • Selecting Trailer Tires • First Tow With My "3500 Max Tow" Package</span></td>
</tr>
<tr align="left">
<td br="" shop="" the="" from="">
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">From The Shop Floor</span><br/>Remove The Cyliner Head<br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:Arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Exhaust Note by Kevin Cameron</span><br/>Piston Evolution<br/></span></td>
</tr>
</tbody>
</table>
<br style="COLOR:rgb(0,0,0)">[/RAW]
