TDR Issue 82 - November/December/January 2013-2014
TDR Issue 81 - August/September/October 2013
TDR Issue 83 - February/March/April 2014
TDRadmin
Staff Member
[RAW]#ad
<table style="HEIGHT:101px;COLOR:rgb(0,0,0)" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="VERTICAL-ALIGN:top">
<font size="2" face="Arial, Helvetica, sans-serif"><span style="FONT-WEIGHT:bold">ARTICLES | <a href="https://tdr-online.com/shop-1/ols/products/tdr-082-novdecjan-201314" target="_blank">Buy PDF of Issue 82</a></span></font></td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">10 Back - Issue 42 Review</span><br/>Issue 42 is Big • Industry News • Twenty-One Brake Questions • High-Pressure Common Rail Fuel system Overview • Transmission Temperatures • Anderson Alaskan Adventure</span>
</td>
</tr>
<tr>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Member2Member</span><br/>Replacing Your Cracked Dash<br/></span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">First Generation<br/></span>No Overdrive Above 80 Degrees • Tachometer Installation
• High Idle Adjustment Screw • Automatic Transmission Noise</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">12-Valve Engines</span><br/>Cold Versus Hot • Overdrive Switch • Sticking Fuel Shutoff Solenoid • 6th Cylinder Access • Lift Pump</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">24-Valve Engines</span><br/>Fuel Pressure Gauge Snubber • Timing Cover Cap • Loose Wire Connection • Clutch Won't Disengage When in Gear • 47RE Transmission Accumulator Springs</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">5.9 HP CR</span><br/>HVAC Blower Motor • Hidden Heater Hoses
• Number Four Injector Line • Low Growl Increases With Speed/Tool Tip • Cruise Control • CEL Tells Me Crank Position Sensor</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">6.7 HP CR</span><br/>Transmission Shifting Problem • NanoNet Fuel Filter • First Oil Change Question • Transmission Shudder in Reverse • Fuel Control Actuator (FCA) Screws</span>
</td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Fourth Generation</span><br/>350 Versus 385HP/Miles Per Gallon Difference? • Do I Need the Aisin?
• EGR • 2013 Gearing • DEF and DPF Question • EGT Gauge</span>
</td>
</tr>
<tr>
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Blowin' In The Wind</span><br/>What is VM Motori? • Nissan Gets a Cummins Diesel</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Technical Topics</span><br/>What is New For 2014?</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDResource</span><br/>This Year's Technical Bulletins • What Do the Model Codes Mean? • Only During the Past Year • TSBs For 2013 • Recalls Issued in 2013</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Your Story<br/></span>Fourth Generation Recap - What Have I Learned With My 4G? • Lesson Learned the Hard Way - Or - How Empty is Empty? • Second Guessing the Editor</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Ready To Travel</span><br/>A Journey Through Time Down the Grand Staircase in Southern Utah</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Four Whaling</span><br/>Cummins in the News • Diesel Versus V-6? • The $50 Blunder • This Day in History • RAM 1500 Diesel - First Impressions</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Idle Clatter</span><br/>Gassy Business • Pooer Running • Engine Swaps • Second Generation Brakes • The Case For Exhaust Brakes • Looking Back 10 Years • "Old Wive's Tales"</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Ranch Dressing</span><br/>Last Issue Recap • Industry Happenings • Battery Charging</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Have Ram, Will Travel</span><br/>Overview of 2013 HD Features</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><br/></span></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Back In The Saddle</span><br/>Engo 9000 Winch • Pacbrake • DDP Dyno Days</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Chapter News</span><br/>CMEP Tour and Presentations • Rams Gather at Columbus For TDR Meet</span><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-FAMILY:arial;FONT-SIZE:10pt"> • </span>The 20th Annual (2014) Western Regional Rally, <br/>“May Madness” Announcement</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDRV</span><br/>Tire Pressure Monitors • Left Hand Turn Signal at Trailer Plug • Factory Installed Tow Package • More Gooseneck Hitch • 2006 Versus 2013 Fifth-Wheel Towing Comparison • Dexter Nev-R-Lube Wheel Bearings • Wireless Remote Backup Camera</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">From The Shop Floor</span><br/>Tap-py Tap-Py Noise</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Exhaust Note</span><br/>What's Next For Diesel Technology?</span>
</td>
</tr>
</tbody>
</table>
<br style="COLOR:rgb(0,0,0)">[/RAW]
