TDRComm
Staff Member
[RAW]<table style="HEIGHT:101px;COLOR:rgb(0,0,0)" border="0" cellpadding="4" cellspacing="8">
<tbody>
<tr align="left">
<td style="VERTICAL-ALIGN:top">
<font size="2" face="Arial, Helvetica, sans-serif"><span style="FONT-WEIGHT:bold">ARTICLES | <a href="https://tdr-online.com/shop-1/ols/products/issue-84-may-june-july-2014" target="_blank">Buy Back Issue</a></span></font></td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">10 Back - Issue 44 Review</span><br/>Back to Issue 44 • Nuts and Bolts • Detailing: Confessions of a Detailing Fanatic</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Member2Member</span><br/>Cleaning Your Diesel Particulate Filter (DPF) • Is There A Difference for the 2013-2014 Trucks? • The 800 Pound Gorilla • And We're Off to the Races (Time to Ditch the 6.7-liter's Exhaust Aftertreatment System?)<br/></span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">First Generation<br/></span>Fuel Lines • No Start • Power Steering Pump Stud and Spacer • Firm Brake Pedal • Lower Than Normal Power Up the Hills • Frozen Parking Brake</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">12-Valve Engines</span><br/>Transmission Shifting Trouble When Cold • Engine Speed Changes When Idling • Wire Color Question • Transmission Noise • Clutch Selection</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">24-Valve Engines</span><br/>APPS Voltage • Fuel Return Banjo Bolt • Head Bolt Torque • Low Voltage at Lift Pump</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">5.9 HP CR</span><br/>Engine Won't Start • Blower Motor Connector • Loose Power Steering Pump Reservoir • Longer To Start and Engine Smokes When Cold • Fuel Filter Canister Hose Fitting</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">6.7 HP CR</span><br/>Regeneration/Biodiesel • Latest Flash Update • 68RFE Shift Flare • Build Code Option Label • Exhaust Pipe Wrap • Good Years for Third Generation?</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Fourth Generation</span><br/>Downloading Uconnect Software Updates • Lube Fittings, Gauges, and Brake Controllers • Dealer Add-On Remote Start System • 11.8-In/300-MM AAM Rear Axle • 2013/2014 Owners Beware -What is a Micro Fuse? • Fuel Mileage? • Kind of Oil Needed?</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Blowin' In The Wind</span><br/>Diesel Pickup Rumors • How 'Bout That Ram 1500 EcoDiesel? • The Fight For Your Attention • Towing Standards • What is J2807? • Cummins 25th Anniversary Turbo Diesel Upfit Package </span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Technical Topics</span><br/>Lubes 101 - What You Need to Know to Purchase Engine Oils – Today and Tomorrow • The Science (And Politics) of Oil</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDResource</span><br/>RAM Automatic Transmissions 1994-2014 • 68RFE Questions • Aisin AS68 and AS69 Questions • A Look at the New Aisin AS69RC • How Hot is Hot: Transmission Fluid Temperatures • Back to the Basics: Change All the Fluid • Conclusion - Ram Automatic Transmissions 1994-2014</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Ready To Travel</span><br/>The Four Corners Area: S Journey to the Center of America's Legendary World</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Four Whaling</span><br/>Small Diesels • Let's Talk Trucks • GM News/Big Pickups • Small Pickups</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Idle Clatter</span><br/>Call Us? • What Were They Thinking? • New Engine Lube Oil Questions • Engine Idling - Again • Speedo Lies • EGR Service • Diesel Exhaust Fluid • Clutch Problem • B-20 Diesel Fluid • Freezeups</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Have Ram, Will Travel</span><br/>Continuing Adventures With My 2013 Turbo Diesel • Fusion Bumpers and Rigid LED Lights • Mag-Hytec Differential Cover • Heater for Rear Frame-Mounted Fuel Filter • BD Exhaust Manifold for 12-Valve Motorhome • Second Generation Ball Joints and Differential Gear Setup • Oil and Filter Change on a 2013 3500</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Back In The Saddle</span><br/>The Devil Is In the Details • Weathertec Window Vents • APS Bullet Grill • HERD Bumper • Performance/Turbo Re-Source • B&W Hitch System</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">TDRV</span><br/>New Ram Hitches • Rust Bugs • Replace Blower Motor in an Atwood RV Furnance • Inverter/Converter • 2013-2014 Trailer Tow Wiring • Slide-In Truck Camper</span>
</td>
</tr>
<tr align="left">
<td>
<span style="FONT-FAMILY:arial;FONT-SIZE:10pt"><span style="FONT-WEIGHT:bold">Exhaust Note</span><br/>More About Oil • Update to PC-11 and Year 2014 Tighten-Up/The More Things Change</span>
</td>
</tr>
</tbody>
</table>[/RAW]
<tbody>
<tr align="left">
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
<tr align="left">
<td>
</td>
</tr>
</tbody>
</table>[/RAW]
