mattymac said:BM, you dumped the clutch instead of just dragging it out a bit. If you need to upgrade to a new clutch then next time slip the clutch a bit more on your take off.
jwilliams3 said:Mark,
What gear? rpm?
Mark, the reasons your tires stopped turning is that your clutch holding and the sled just plain put the hurt on your engine by dragging down the rpm's.
I guess it could have slipped once the sled stopped you. But the clutch didnt end your pull. The sled did.
Big MAK said:Dang all that momentum and it stopped so fast...
I felt my clutch let go at the end; and this vid confirms it. See those rear tires just plain stop turning like I hit the brakes? Time to give Peter a call. I had the power; clutch didn't hold it.![]()
jwilliams3 said:Auto pullers do great.
But there is only one place I would get an auto pulling transmission done and that is Haisley Machine.
PM if you want more info.
