What exactly does the CP3 do I see the Modded CP3's now and is this needed along with a Fass or Walbro etc.
Where can I go read axactly what this unit does
rbattelle said:FASS and Walbro are both replacements for the pump that transfers fuel from the tank to the CP-3.
rbattelle said:Of course, the next logical question is, "why would anyone want to replace the transfer pump with a FASS or Walbro (or something)?". There are 3 main reasons:
1. You want to add better filtration and the stock pump can't push enough fuel through a very fine filter (say 2 micron).
2. You believe the stock fuel transfer pump (usually called the lift pump) is unreliable. The lift pump represents a single point of failure for the truck - if it dies, the engine won't run. Lift pumps mounted externally on the engine (pre-2005 trucks) have a nasty history of dying. Lift pumps mounted in the tank (2005 and later trucks) seem to be far more reliable. So much so, in fact, that Dodge now retrofits all 2003-2005 trucks with failed external lift pumps with new in-tank pumps.
3. You want to add a lot more power to your engine, so you need more flow from your fuel tank to your CP-3. A bigger pump does this for you.
Ryan![]()
daytripper63 said:I also believe that if you run your rail pressure to low you not only run out of fuel to power the motor but the excess fuel that is normally in the rail is what cools the injectors, so by running the common rail dry or low you can be damaging the injectors as well.
Therefore another need for a stronger lift pump when modding
