Tech II monitor
Banks New Tuner Truck Trio
Anyone have pic's of their trans temp sensor installed.
Anyone know where I can get a Tech II monitor for the common rail? Or the Chrysler equivilant? I see the D-max guys using them to monitor rail pressure and other sensors.
Thanks
I would check out a Snap-On MT2500 scanner on ebay and then load the latest software. I use an MTG at work which is the graphing version and have to say that the latest software is really nice as you can do things like injector kill/balance tests, pinion factor changes for different tire sizes and such.
It would be less expensive than a DRB and still get the job done plus be useful on other makes.
That Snap-On scanner is $3695. A bargain when you consider a DRB-III is $6000.
Of course, I can't afford $3695 any more than I can afford $6000. :(
-Ryan
