My 97 2500 2X4 with 5sp manual has the same jerking symptom (only while towing)described by several others in the discussion forums. I approached the local Dodge dealer about the TSB #18-29-97. (This TSB is available on the TDR website)At first, the service manager said my truck wasn't covered because it was out of warranty (Only 33K miles, but 4 years old). When I pressed him on the issue that the symptom has been prevalent since new and is published on the net by many owners and should not be subject to limitations of the warranty, he said that he TSB's are only "pointers" and are not always accurate. He further indicated that he would consider "sharing" the cost of the remedy specified per the TSB if his "evaluation" determined that the throttle linkage was indeed the cause of the jerking. I declined his invitation to make an appointment for an evaluation because I do not believe I should share in anyexpense to remedy the problem. I have two questions for anyone who reads this and who is prepared to answer: 1) Isn't the warranty period, if applicable to this TSB, 100,000 miles since this problem relates to an engine item?, and 2) since the TSB clearly states, "If this situation is described by the owner, perform the Repair Procedure," shouldn't my description of the problem be sufficient to have the work performed? I am anxious to hear your opinions.
