Ted Jannetty redefines exceptional customer service - JRE 4" Exhaust Troubles
Which 4 in. exaust? JRE or Jardine?
Fuller RTO6610???
<font color=blue>Ok heres the scoop on MY JRE 4" Exhaust system.
First off yes the install took longer then anticipated, but after a lengthy conversation with Ted this morning we found out mostly why things went wrong like they did.
First off the shipping was not great. As I mentioned above I was not here when it arrived. Ted informed me that I had 7 days to claim damages against UPS, but I didn't know that at the time I thought since I didn't recieve it personally that I was stuck with it. The eggshaped pipe ends were fixed and were more of a minor annoyance then anything. The welded hanger that we had to rebend was probably also damaged by the shipping. The box I had looked like it had been torn in half and basically retaped together. I really couldn't believe it. Somehow the K&N air filter that was in there survuved. #ad
Here is the problem we discovered :
You are told to reuse a clamp from the factory muffler that when in place will set the pace for the rest of the exhaust system. MY hanger from the factory was welded onto my muffler and well would have been more trouble to remove then it was worth. That was the start and root of most of our problems we had as this clamp is basically the key ingredient on where the whole system will hang. Ted stated this is the first he has heard of this and that he will include that clamp (he knew the part number off top of his head) in all future kits from this day forth. The way he described the muffler should sit is nuthing like mine is sitting which is why we couldn't use the rest of his supplied hangers. My truck was made in Mexico. When in the porper posistion Ted stated there should be 1" of welding space for each hanger, this was not applicable in my case because we fabricated our own hangers!
Ted was very concerned with my situation and literally asked me what he could do to make it "right". I will not disclose what the details are (to keep it professional) but Ted has shown his commitment to making his customers happy.
I am going for my new TC and Valve body tommorrow so I had to have this stuff in there for my dyno runs I have scheduled.
Ted Jannetty is doing everything he can to make me a happy, satisfied customer.
I will definately still recommend him and his business in the future based on this level of customer service and responsiveness to the situation. If this was my "first" dealing with him I might have been a little more upset then I truely am, but because of previous converstions with him I KNEW he would listen to my concerns and act on them. The fact that is was the weekend complicated the whole situation.
I may be around for a 2nd installation of a JRE system on another truck in the next couple of weekends. So for now I consider this a "one-time" situation.
If we use the correct clamp and we still have troubles then I will post them, but until then I would still suggest looking into the JRE 4" Exhaust.
To anyone who has installed a recent exhaust system, for feedback reasons was the clamp on the front of your muffler welded in place? We are trying to determing when this started taking place. Please contact Ted or post here on this thread with the information. He is always looking to improve his system.
I am completely satisfied with my exhaust and the sound of it. Only its gonna cost me more fuel milage because I WANT to drive around with over drive off to listen to it from 2100 rpm to 3200 rpm.
<font size=+1>Ted Jannetty of JRE STILL has my business and reccomendation. </font> It its not right he will make it right, period, end of story.
  • <font color=blue>
  • Eric D. Howard - #ad
    - BOMB'er! - #ad
    - TDR Member since April 8th, 2000
  • 2001 Dodge Ram 2500 HD 4x4 SLT Auto Reg cab Cummins Turbo Diesel 4. 10 gear ratio LT265/75R/16 tires
  • Patriot Blue Pearl Coat, Agate interior, Leather seats EVERY option, Silencer Ring AWOL
  • JRE 4" Exhaust, "Hot" PowerEdge, Autometer UltraLite Gauges (EGT, Custom Boost, transmission temp), K&N Airfilter</font>
<font size=-2>
[This message has been edited by KatDiesel (edited 07-31-2000). ]
Katdiesel- I will be meeting you tuesday when you have your trans. upgrades Dave wants you to drive my truck to see if you like the way I have mine setup I have a JRE exhaust on my truck also so you can see how it mounts I also think Ted J. is a stand up dealer had a problem once and he more than took care of it if I call he will talk to me and answer Questions and will answer e-mail which is worth alot to me
<font color=blue>Ok, thanx for chiming in here. I should be there by 11am I hope (leaving at 5am) Appriciate ya letting me drive your truck and taken the time the to come down there.
Its gonna be fun! #ad
Of the 4in systems I have dabled in, I always try to convince the guys to stay away from a total bolt up system and go witha weld on system. Exhaust work sucks and it really sucks laying on your back. To anyone thinking of buying an exhaust system, go let an exhaust shop install it. Save yourself the cusing and headaches.
2001 6-speed 4*4 Quad dually. Diesel Dynamic Injectors, 14cm housing 4in exhaust. Jacobs brake.
kat , i have a 2000 built middle of december in st. louis , it has the muffler clamp hanger in front of the muffler , the hanger at the rear of the muffler is welded to the muffler , i take it that your system has the hangers welded at both ends ?
i can see where this hanger sets the height for the rest of the install , but since i'm about an 1. 5 hrs from ted and got mine thru a secondary source with a pipe missing i just made the trek to JRE for the install and picked up my VA on the way.
the service i recieved was top notch ,and even though i didn't purchase it directly from JRE they were more than fair with the install charge .
Ted Jannetty is a real good recommendation from me too as I ask if he could send me the muffler clamp as mine was like KatDiesel's (its welded) and Ted sent me the clamp 3 day air with no questions asked so hopefully my system will go on a lot smoother than when we installed KatDiesels. Thanks a bunch Ted.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, air dam, 4w ABS, camper and trailer tow packages, fog lamps, CD/cassette, HD transfer case, snow plow prep, travel convenience group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, PowerEdge, 4" JRE exhaust, BD exhaust brake. 12500 miles as of 7/26/00.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
Your welcome Doug, My pleasure!
Thank You
Ted Jannetty
Ted Jannetty, Owner President Jannetty Racing Enterprises Inc.
97 3500 4x4 club cab 5spd. RED, JRE stage 3 power kit, JRE 4" exhaust
JRE 1/2 inch fuel system, Cummins 370 hp injectors, Prime loc,
Cummins chrome kit, US Gear 20% over drive, 3. 54 posi, Autometer
gauges, boost, and Pyrometer, BD exhaust brake.
97 Ski-Doo 670 turbocharged
99 Honda Forman 450 ES
<font color=blue>Yep you got it both ends were welded. So Ted will be sending that clamp with all exhausts shipped for 01 trucks (ETH and ETC's).
