JJW,
I have had several Lance Campers and they have a 12 volt option on the fridge which draws approximately 18 AMPS. The 12 volt hot line wired in the factory harness will not operate the fridge very long without running down the camper battery.
I ran an 8 gauge wire from the driver side battery, through a 40 AMP circuit breaker and a heavy duty isolator relay operated by the ignition switch, back to the camper receptacle. The relay keeps from draining your cranking batteries if you forget to unplug or switch off the 12 volt drain in your trailer.
The 12 gauge factory supplied wire all the way to the rear of the truck has too much resistance to handle very large current loads. There is no isolator relay in the factory trailer tow wiring harness.
Bill
Y2K 3500QC, 6 Speed, 4. 10, SLT+, Camper & Tow Pkg. , Westin Chrome Nerf Bars, Mopar Flaps, EGT & Boost Gauges, ECM Controlled PacBrake w/BD Switch on Gearshift, Painless Wiring Kit, Mag-Hytec Diff. Cover, Rancho 9000, Air Lift 5000 Air Bags, '01 Lance 1140 11'6" Slide-In Camper, Torq-Lift Camper Tiedowns
