Engine/Transmission (1994 - 1998) Temp and oil sender location
Engine/Transmission (1998.5 - 2002) help please
Engine/Transmission (1994 - 1998) new transmission help
Where can I find the above on my 12V ?? I need to replace both. I think I see one of the passenger side of the engine , just below exaust port # 2. If that one is the oil sender, iy doesn't look like the replacement I bought.
Thanks
The oil sender is under the fuel pump and about 4 inches rearward of the power steering reservoir. it takes a 1 1/16 socket and don't forget to slide the locking tab on the wire harness before you try pulling it off.
Coolant sender is on the head(driver side) towards the rear and above the fuel filter( assuming it's in the same place as the '97's). The wiring harness tends to block it from view. The connector has a ear on it so you can't just pull it off.
