I'm having trouble regulating the heat and A/C temperature in my truck. The heat isn't getting very hot - even with the heat control set to high heat. If I run the fan at high or second from high, the heat is ok - but not as hot as it used to be. I think the problem is the actual temperature of the air coming in just isn't as hot as it should be. If I turn the heat control knob toward cold, the temperature doesn't seem to change at all until I get about 3/4 of the way to full cool, and then it pretty much goes to full cool - no gradual change. I noticed in the summer when running the A/C that it was full cold and at about that same point (3/4 cool) it would go right to heat - no gradual change.
I have fresh coolant in the truck, and the t-stat is working correctly. The heater core is not plugged. Vacuum seems to be working fine because all of the other controls are working. I'm thinking the blend door is ok since it does change temperatures - just not gradually. I'm wondering if it's the temperature control switch. The FSM hasn't led me to any conclusions, either. Has anyone else had this problem, and if so, what was the cause? Thanks in advance for any help.
