Originally posted by JPM
In a straight line everything is SAT ( except the MPG's go down the crapper!) but turning sharp , this truck has the worst binding , lurching that I have ever seen. My ole "50 Power Wagon was better! Is this normal for these?
Originally posted by JSchutz
In a sharp turn the inside tire is treaveling a much shorter distance than the outside tire and with everything locked up in 4wd "lurching" is inevitable. That's why it's not good to be in 4wd on dry pavement--tough on tires and drivetrain...
Originally posted by ceastmen
No flames intended,... just info!
The "bind effect" is due to the difference in distance traveled by the front and rear tires (front driveshaft vs. rear driveshaft), it's not the an inside vs. outside tire issue. In a turn the front driveshaft turns fewer times versus distance traveled than the rear driveshaft. The rear axle does not track the front. This can be seen if you make a shrp turn in snoe, you will see 4 paths in the snow, indicating the rear axle is not tracking the front.
I'll clarify further. When you put your truck in 4WD you are intentionally locking the front and rear driveshaft together, this is done in the transfercase. Now, if the front drive shaft turns fewer times per distance traveled as compared to the rear driveshaft, both the shafts will twist creating severe torsion (like winding up a spring) then they will unload when the built up torsion exceeds the traction limit of one of the tires,... then the process repeats if you continue in a turn on dry pavement and it lurches. This effect is more severe the longer the truck. Remember 4WD does not lock the inside tire to the outside tire, only a locker or spool will do that.
Originally posted by SRadke
The bind is traction related not component related. Remember, all those parts are turning all the time in the 3g's, there is no axle disconnect or hubs. If they did bind they would do it 4wd or not.
-Scott
Originally posted by Mopar_Mudder
He is correct, but also the sharper you turn the worse the effect is, so you notice it more on the newer trucks with the sharper turning radius compared to the old timers
Drive a truck with different gear ratio in the front and back once, then you will really know what bind up is, LOL
