FIXED IT!!! Long reply!
I still had the short after replacing the switch. I removed every bolt I have put in the last few days, nerf bars, front mud flaps, tool box bolts... . STILL SHORTED!!!
I soldered up a clearance light with leads long enough I could lay it on the ground. That way I could see it from anywhere under the truck. I wiggled and shook wires all the way up the frame, I even let the spare down to check where the wires run under it. I decided I was going to cut the black/yellow wire under the cab to isolate the trouble somewhat. I pulled the wires out of the loom and was trying to get enough slack to work and cut it when I found a nice plug right behind the front wheel. I unplugged all the wires that lead to the back of the truck. As soon as I did it my low fuel dinger started sounding.
I looked over at the test light on the ground and it was still burning -- So I figured the problem lies in the front of the truck. Just for fun I stuck in a fuse and turned on the lights --- Cab lights and front parking and dash all light up and stay lit. Hmmm! I hooked up the homade test lamp and it still lights. You are right Thomas, enough ground through the bulbs to make the test light burn.
Now I know the problem IS in the back half of the truck. I decided to unhook all bulbs. I was able to unplug every light from under the truck. Much easier than removing the bulbs. I didn't know there were that many plugs back there!
I tested the black/yellow with my meter and it does NOT show short. I plugged the harness back in behind the front wheel and turn on the lights... cab, dash and front parking lights all light up again. Now I'm getting somewhere! I started out plugging lights in one at a time until I finally blew the fuse - Darn 3 bar light on the tailgate. I have not figured out exactly where at on the light yet. I'll work on that tomorrow after work. I finished plugging in the rest of the lights. Oo. ALL is GOOD!
I did break a prong off one of my marker lights on the dually fender. I called the parts house, they don't show one in their book so it must be a dealer item. I'll run by the 5 Star tomorrow.
Thomas thanks for your help. I sure thought it would have been in something that I added to the truck in the last couple days!! It's sure nice to know about the plug behind the front tire on the drivers side - I could help isolate in the future.
On a good note - I did spend 39. 00 on a new switch so now the little background lights work on the dash!
G'day!
Brian
