Test Your Diesel Knowledge
Duramax Dyno Report
Low Sulfur Fuel - Stuck Injectors
Red nosed reindeer?
Rudolf Diesel did not build the machine that bears his name. Rather he developed a theory of internal combustion, plus a few crude prototypes, which he thought would liberate mankind from factory work. Diesel's first patent of a four-cycle engine was in 1892. None of the prototypes he worked on in his lifetime worked very well.
Originally posted by Doc Tinker
What did Rudolph Diesel invent? :)
Compression ignited engine (using coal dust as the original fuel).
Doc, you probably had some other obscure fact in mind, knowing your nature. ;) :D
If I recall correctly he invented the internal combustion engine. Then some other guy stole/released his version first. That is were "automobile" came from. Diesel then went to find a more effiecint egine the compression driven engine. Did I recall correctly or an I full of it?
Boy. . You guys are good! Here is something for you to ponder.
"When Rudolph Diesel produced his famous engine in 1896, he assumed that the diesel engine would be powered by a variety of fuels, especially vegetable and seed oils. Rudolph Diesel, like most engineers then, believed vegetable fuels were superior to petroleum. Hemp is the most efficient vegetable. "
That came from here
Just think. . our engines might have been called HEMP engines instead of DIESEL
Doc
15 years ago I would have thought the 5. 9 Cummins Turbo Hemp engine sounded cool. Now is just sounds funny.
I heard once that during the process one of Rudolph's engines blew up or something and he lost a couple fingers.
I wonder if that was true?
Eric
Smoking a Diesel would have a whole new meaning with the Cummins Turbo Hemp engine. At least those that got smoked would be happy about it.
HHHHHHappy Trails
:p
