I have never beleaved my Isspro EGT gauge since the day I got it.
When outside temp is 70, and the truck is stone cold it reads just over 0.
At idle hot, it reads 200. Never stays above 300 at a light for more then 15 sec.
So I decided to test it. My Friend got me these things called Temple Sticks. You rub them on the end of the probe and they change colors at a pre set temp. we pulled the probe, market it and heated the end that goes in the manafold with propane Below is the results. We did several tests with each temp temple stick.
Stick Temp Gauge Temp
300 200
1100 1000
1200 1100
Now they say they calabrate the gauge at 1200, and 1100 is within 10%. Only problem is when you are towing and see 1400 is it really 1400 or is it 1500?
Anyway, Guess I will call Isspro on monday.
This is my orginal thermo coupler but my 2nd gauge (the last one would not read below 150 cold)
300 200
1100 1000
1200 1100
