Erik@tvp
Thanks for providing the hp and torque curves.
However, why dont you show 1300rpm on up? I'd like to see the whole curve as some of my OTR driving is around 1500 rpm.
One of the many reasons I chose the AFe was that they were the only manufacturer to provide the power curves. Everyone else just talks about total airflow.
Total airflow is important, but so is velocity and direction. Those intake manifolds must turn the air 180deg from the CAC pipe to the engine inlet. I bet at the lower boost levels and rpm, those vanes really help direct the air uniformly into the manifold as opposed to only flow at the outside edge. Air acts just like a car on a banked turn. It will not fill the entire manifold and you will have dead spots.
I researched the AFe quite a bit and the things that impressed me most about their design were the flow vanes and the fact that its the only true drop-in. Plus, Bob 4x4 recommends it and he definately knows what works... :-laf
It has two holes for the harness attachment and the dipstick doesnt have to be moved to the very outboard side. I tried to move my dipstick outboard before making the decision and it was under alot of stress.
Also, I can't see the total value in the composite manifold vs. the very nice powder coated and polished cast aluminum part. What I'm saying is my perception of the composite is that it should cost less.
I'm definately not trying to say one is better than the other (especially with the power curves shown), only trying to say why I chose one over the other.
Regards,
Louis
