I am wondering about testing the AFC housing itself for boost leaks.
I disconnected the metal line to the manifold and connected a rubber hose to the line and pumped it up with a MityVac. It easily got to 5 psi but I could not use the MityVac to get it any higher. I had to connect the line to a cylinder of dry nitrogen and then I got higher readings. Is this the way its supposed to work?
I opened the AFC housing to check for tears, etc. and did not see any in the rubber diaphram.
Any comments would be appreciated.
Thanks,
Brian
Thanks,
Brian
