Im just thinking out loud here
but I think this is important enough to mention
P0500 code
why is this showing from unpluging the pump???
does the pump have its own vehicle speed sensor???
the dealer told me that 0500 is for gassers only and we should be getting a 0501
my dealer has proven to be quite illiterate on the subject of these diesels so I just shrugged it off.
but , 6 months ago when this problem first popped up I got an 0500 and 0253
0500 - no vehicle speed sensor signal
0253 - fuel pump fuel valve open circuit
I havent got these codes since then but maybe the problem relates to them anyway.
The pump works fine when I take the brains away (ecm,etc)
then idles like crap when the "smarts" are installed
I dont know how to diagnose this but
Is it possible for pinched/bad connection / crossfiring wires between the ecm and pump????????
How would it relate to 0500 and 0253??
If so how would I find it???
I am still going to replace the APPS because of the fact that the stumble is not as bad with the cruise on
( if I can just get the dealer to get me one)
but with my luck that wont fix it either:{
Yesterday I got the chance to try a power max 3 in place of my comp (thanks to a couple of very nice people)
It did not remove the bad idle or stumble so the problem is in the truck.
Power Max 3 - good
edge comp - good
both good and different at the same time
now I have a real problem - I like both boxes but wife wont let me keep them both:{
