Engine/Transmission (1994 - 1998) testing tps lowest voltage 3.7
Engine/Transmission (1994 - 1998) '94-'98 Lift Pump Replacement
2nd Gen Non-Engine/Transmission Transfer case questions
trying to figure out why overdrive does not work testing tps with key on and the lowest we get is 3. 7 volts
any input is appreciated
marcel
The TPS voltage should be close to 1 volt at idle. Check out TPS mythbuster it has a bunch of good info about the TPS. I have an in dash TPS. It allows great control over shifting and is alot less expensive than replacing the TPS.
