Texas Limo
5 Star oil change--and stink
SYNTHETIC POWER STEERING FLUID
Check this out, to bad it's not a DODGE #ad
http://albums.photopoint.com/j/View?u=1269462&a=9396567&p=39607401&Sequence=0
1997 Dodge Ram 2500 HD / Club Cab, Cummins Turbo Diesel (silencer ring removed), 4. 5" Skyjacker Double Flex suspension lift, 36x14. 5"x16. 5" Ground Hawg radial tires on 16. 5x9. 75 Weld Super Singles, dual steering stabilizer, 4. 10 precision gears, 33-tooth Speedo gear, Rhino liner, Grizzly double bent nerf bars, Bushwhacker flares, Kanduco grill insert, Confer super skid axle truss, DT Trac-bar, Moog tie rod system, Fabritech Traction bars, Energy sway bar bushings and end links. Truck Pic's
Yeah, not a Dodge...
but it'll likely take Cummins to tow that terminal scrub radius, straight line suicide sled in for Cackle Fixes or Turbo Bolts droppings?
Max
[This message has been edited by Mad Max (edited 02-02-2001). ]
