Engine/Transmission (1998.5 - 2002) Thanks to TDR
Engine/Transmission (1994 - 1998) High RPM missfire
2nd Gen Non-Engine/Transmission Fender Liners
Just wanted to say thanks to TDR. . I've been lurking and searching for a while thought I would finally post up... Here's my list since joining... ball joint RnR,isspro gauges,BHAF,silencer ring,edge comp,70. 00 lift pump and South Bend Con-OFE(just did it today)
Next up. . Starter solenoid contacts,oil leaks, new exhaust and exaust brake
Definately would not have been as easy without TDR :)
Thanks,
Aaron
the starter contacts replacement is simple and tough. the top starter bolt is fun. i still have the stock crankcase breather and was pretty greasy when I was done. make sure you have an assortment of 12pt 10mm tools. i got it done with a combo wrench and short socket. be careful not to stip the contact nuts that hold the starter contact studs they are a soft metal (at least mine were).
