Just got through installing my needle valve into the fuel inlet banjo - in the process of rotating it I hit the rubber boot (or what's left of it, should have replaced it awhile ago).
Re-hooked everything and cranked it a couple times to bleed the air - fired right up.
Whent out to run to the store and it would die immediately upon starting.
Thanks to spending time here I realized it was probably the fuel shutdown solenoid.
Pulled the solenoid and a piece of the boot had gotten caught up in the spring.
Pulled everything apart, cleaned it up and re-installed it without the boot for the time being so I'm at least mobile.
Plan on ordering a new boot from Larry B.
Or should I just rig it w/ a bicycle tube?
For those that did the bike tube thing - what size tube? I'm assuming a mountain buke tube would be best.
How did it seem to seal up around the edges?
Or, is it best to do the Larry thing?
