that horrible oil smell
Rickson Accessories
SPA Backlighting: Too Bright!!!
Well i just learned that my truck is apparently supposed to have that smell after an oil change... that is a relief because i was just about to make an a** of myself at the place where i bought my oil because i thought there was something wrong with it #ad
anyway i have read elsewhere that there is something you can do to try and help with this problem but i don't remember what it was... could anyone help me out with this... . thanks guys
2001 3/4 ton driftwood 24 valve HO 6 speed; straight piped, silencer ring out
BodyGuard front end replacement. Alpine CD player, Kenwood 750 watt amp, 2 10"
JL subwoofers custom truck box behind the seat.
Jason
Hey I know what you mean. I bought geno's catch bottle. When I moved it, I was very happy with the results. That odor after oil change was gone and no more mess. There is a lot of option for fixing the problem, but this is the one I pick for me. #ad
2001. 5 2500 Q\C,lwb, white/w gray int. ,HO,6-spd. ,3. 54,trailer tow, camper special,custom bolt-in G/N,Pryo/Boost,
See'ya down the road Michael
Yeah my mother, who drives the school bus route, was complaining about that smell after an oil change for the bus.
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo(37psi),PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '97 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
FF1381
Another option is to remove the bottle that came with the truck and run heater hose toward the back of the truck.
I use Shell Rotella-T 15W-40 and did have a slight smell in the cab before I ran the heater hose. I used 8 feet of hose and ran it down near the starter, into the frame, then back out near the middle of the truck where there is a cross member. Point the hose downward so any fumes that condense drip out. That is why I did not run the hose any further back inside the frame because I was worried that fumes would condense out in a low spot, fill the hose and stop any fumes from escaping.
The only problem with this is that I have had a co-worker ask me why I smelled like diesel. I told her it was my new cologne, Cummins.
Lyndon Hendry
Chief Equine Officer (CEO) and
President for Life
Head Over Heels Farm
2001 2500 QC LB ETH/DEE 3. 55RE Patriot Blue
Pop-Up Hitch, Stock engine except for MIA blow-by-bottle
"An oil burner for the hay burners. "
Eventer.
where is the blow by bottle located at, i am interested in how every one is changing this
Jason
[This message has been edited by FF1381 (edited 01-21-2001). ]
hey ff1381
Jason, I bought it at Geno's Garage
www.genosgarage.com
It is fairly new product
it is in their catalog # 30
Real easy to install hope this helps
I just changed over to Delo-400 from Rotella. I got no smell from Delo. The Rotella was very stinky. I will use Delo from now on.
Y2K, 2500, 4x2, QC, 3. 54 LSD, Auto, patriot blue. K&N, silencer ring put back in. 14000 miles as of 1-05-01. best milage:28. 5 mpg. transmission reflashed
hey rusty,
where did you find geno's drip bottle, i can't find it on their website?
Jason
2$ Worth I have heard of this before and found out a thing or so. Since NEW (up til 800 miles when I found the problem)99-01 Valve Cover gaskets in the rear of the motor have either crumbled or been pinched out of place during assembly. There is a Technical service bulliten about the oil smell entering the cab after oil changes and has re occured even after emptying the bottle. Brought mine in and bingo after showing the tech the NEW oil residue on the back of the valve cover they soon found the tsb (hmmm handy diag tool at alldata.com)Fixed and gone for good.
Y2K+1 3500 4X4 Quad Cab Powerpacked
Keeping the rubber side down 'n' shiny side up Will Bring a smile at the end of each day (hopefully)
sdalton,the Delo won't eliminate the smell. My Rams and tractors all stink after a Delo oil change,and have for the last 25 years. My Chevron jobber told me that the smell comes from a wax type additive that is used to keep the oil additives in suspension during storage,when the oil is heated the wax burns off and causes the smell. It could be that Rotella has more of this additive and thus stinks more.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
hey fellers, I dont know what your talkin about but I do know that when my wife wants to get friskey she puts a little mobil 1 behind her ears and it drives me nuts (Litterely) get it ,drives me nuts, and then look out when she gets out the visqueen!! #ad
I head out to the shop and get a quart
Kevin 2001 eth dee
I never thought it smelled bad, I certainly wouldn't describe it as "horrible"... . From the time I was big enough(3 years old) to use a creeper to scoot under my daddy's Ford dump trucks, and Mack tractors with Fruehauf dumps, stick my entire arms in drums of axle grease, and goose the mechanics with compressed air, I loved the smell of oil, and diesel. It gets in your blood. Running Amsoil now, I really miss that "real truck" smell I would get at oil changes.
To each, his own... .
Tom M.
Secretary of the Great Lakes Turbo Diesel Registry GLTDR B. A. D. Boys www.lubedealers.com/meers.html
FF1381
Facing the engine, the blow-by-bottle is just to the right of the center line about half way down the engine. It is a small plastic "pill" bottle about the size of a 250 count aspirin bottle with holes in the side.
I checked mine at about 3,000 miles and oil had already blown by (hence the name?) the holes onto the engine.
I went to O'Reilly's in the nearest town and picked up a hose connector (plastic) and 8 feet of heater hose. I already had some plastic cable ties that I used to tie the hose down so it wouldn't flop around.
Rather than the plastic loop that holds the bottle to the engine, I used some metal pipe strapping to hold the hose in place so it doesn't move.
Let me know if you need anything else. BTW, I think this qualifies as my first BOMB!
Lyndon Hendry
President for Life
thanks eventer i will have to start working on that pretty soon... .
i guess the blow by bottle and new front end springs are the next two things on my list
Jason
Very cost effective and plentiful source for blow by bottle.
1. Get a small Aberfoyle Springs 16. 9 OZ bottle.
2. Drink the water or pour it out.
3. Take a pocket knife with a sharp point and make about 8 1/8" holes all the way around the top of the bottle.
4. Get a hose clamp that will fit over the mouth of the bottle. Put it on there and snug it up just a little.
5. Get your creeper and go under the truck near the driver side door. And roll up to the blow by hose. Slide bottle onto hose about an inch or so and tighten until you can't pull it off. If you have a 24 Valve Engine it will be on the front of the engine. Much easier.
6. Empty or replace the bottle at each oil change and think about the $40. 00 you saved by making your own drip bottle.
:d:d
[This message has been edited by McGrady (edited 01-25-2001). ]
