I know this has been discussed in several threads, but I couldn't find a definitive answer to my three questions, so here goes . . .
I installed a piece of cardboard in front of my A/C cooler as a winter front. It extends from the top body crossmember (where the primary latch for the hood is mounted) down to the bottom of the two cutouts in the bumper (where the fog lights are mounted), and it goes from side to side, just a few inches short of the headlight assemblies on each side. I think this completely covers any area where the fan would be, so the blades should not be traveling through regions of markedly different airflow. So -- do I still need to worry about stress on the fan blades which would normally be caused by having the path of the fan blades partially covered?
Next question: Is it going to damage the fan hub to be totally covered? Keep in mind that this cardboard is several inches away from the fan, since it is in front of everything, including the wire window screen that is supposed to protect the A/C condenser fins from rocks and bugs. I would think this would allow some air to indirectly reach the radiator and the fan hub.
Which leads me to my last question: How much risk am I taking of creating too high of EGTs, since the function of the intercooler is obviously being impaired by blocking most of the airflow through it?
My truck has no power enhancements (yet) and it is very sickly to boot -- I can't even pull my boss's 13k - ish loader/trailer combination at highway speeds. The few times I am towing something more than an empty bumper-pull trailer, it is pulling the 12,500 lb loader, on back roads usually, barely reaching 20mph. If it is snowpacked or icy I am usually in 4LO with chains on, so I am really going slow. I don't have a set of guages yet, but that is hopefully soon going to change. Oh, and temps here around Colorado Springs area can vary greatly--down in the single digits for a few mornings, then in the teens, and the next week they may be around 50 F in the daytime.
Sorry for the long post. I want to be able to get better heat in the cab on cold days and mornings, but I don't want to be damaging things in the process. Thanks for any input you guys might have.
CTD12V
CTD12V
