My interest on this was sparked in another thread and thought I would start a thread specifically about this subject. I am very interested in understand what the impact of slowly raising HP on our trucks with things like injectors, fueling boxes, timing boxes, larger turbo's etc... is having without us knowing right away? What failures have others experienced?
My thinking here is that a lot of people have been doing this and are unaware of the proper way to truly build up a high performance engine. I think often things like valve springs, valves, pistons, piston rings, etc... are often overlooked. If so, what has been the true impact on lengevity and reliability to these engines?
Also, if you were going to build a 600 HP Cummins 24V the *right* way from the ground up for both power as well as reliability and longevity what would you do? Money is not an object!
Here is what I have learned so far...
1. Ceramic coated pistons
2. *better* piston rings (not really sure what kind)
3. O-ringed head AND block
4. good head gasket
5. different Cam
6. stiffer valve springs
7. stronger valves??
8. ported and polished head
What am I missing? what else have others done. How "bulletproof" would an engine with the above be?
Thanks
Phil
4. good head gasket
5. different Cam
Thanks
Phil
