Originally posted by ToolManTimTaylor
Not for anything the Dodge cummins combo PALES in compairison in terms of failure rates , down time , and even lemon costs when put against the other brands. Yes there are a few problems like there have been mentioned above however there are just a FEW complaints as you mentioned a few above when you look at the 1,000,000 cummins equiped rams that are floating arround out there.
There are what 16,990 members on board here that maybe 8,000 post. Out of that 8,000 maybee 2,000 have posted problems weather they even are failures or not like the above. So maybee 250 cracked blocks (i see that as the biggest worry) and 700 cracked manifolds (Minor as the manifold is cheap) and not every lp , Vp is bad. There are tons of guys that have well over 100K on the VP. Many have over 200K and have their stock VP.
I couldn't agree with TMTT more. We have no leaky injectors, no "dead pedal", no idle romp, no cackle, and no glow plugs
If you are under 100K, the warrenty will pick it up, unless you modify your truck. I guess the background I come from is from a truck I have modified to run twice it's rated power. $. 04/mile is nill in comparison to money I have spent on my trucks making them faster, My trip to Thunder in Muncie cost me about $3. 00/mile, not including fuel, and I drove about 2,000 miles round trip. My reality is much different than others on this board, and by no means are my trucks, or me, "Main stream".
One thing I do know about the Cummins,, The weaknesses are known. Isn't it nice to know that an injection pump failure is on the "might-happen-soon" list,, compared to a Duramax, or PowerStroke, where you have to have the tow truck on speed dial, because anything could break at anytime?
I feel the Cummins is the most problem free motor on the market. It is way overbuilt, and that might even be a slight downfall in the long run, when it starts wearing out suspension components from the weight, and you have to park a good motor when the outside of the truck falls apart. But, it is nearly an unstoppable machine, and when it does stop,, Most DIY'ers can fix it in the driveway.
That' s my take on it. (I was scared to say $. 02
Merrick Cummings Jr
