The InTake lift pump "fix". One year later
Edge and smarty
Smarty VS. Edgue Juice-- Conclusion
Less then a a year ago I had my stock motor mounted lift pump crap out. I bought a low pressure gauge, rail gauge, and had the dealer installer the intank one.
Pressures were 11-12psi at idle, 10 cruise, no less then 5 WOT with all the boxes up. this was perty much from 0 - 100+
Winter came around and I notice a slight drop in pressure across the board... Well, it's winter. :)
Winter is finally gone again and I've not seen the pressure increase to last summers numbers.
9, some times 10 idle. 7-8 driving. Dan near 0 WOT. I've even felt the motor cut out for a second once.
It's time for an AirDog. I was thinking Walbo, but I like the idea of the air separator and the one unit holding the filters.
So, with this said, the intank pump isn't much better then the stock motor mounted one. :(
