The Juice "HOT"
P0514 Code
3rd gen aftermarket mufflers
:D Anyone know when the Juice HOT will be available? Any word on the HP/TQ on that unit? I would suppose you'd need all the same upgrades that the TST would require for that setup, i. e. turbo, transmission, pusher, exhaust, intake etc. I wonder if you need or if you could even use injectors with that setup or if a stack with the EZ would be a better way to go? Thoughts?
I haven't heard anything yet, but I thought there was a thread recently that mentioned that the CP3 was capable of up to 800HP.
Look here:
https://www.turbodieselregister.com/forums/showthread.php?t=119949&highlight=CP3
https://www.turbodieselregister.com/forums/showthread.php?t=119145&highlight=CP3
Here's a quote from Keith LockLiear:
Different truck though. The stocker we tested was BONE stock. Made the numbers shown in the graph.
Lawrences truck already had the 2's and turbo on it when we got the Juice to test. With the turbo and 2's, it made 384 (stock was 307). Juice on 5 made 470, stack the EZ made 501.
Pusher pump does not seem to be needed on the 600's.
The thread containing the comment is here:
https://www.turbodieselregister.com/forums/showthread.php?t=120057&page=1&pp=15
Jim
