O. K. I'm really going out on a limb now. I've got ten hooks under my belt and I am wanting more. In my area, we run street diesel with front hanging weights and 2. 5 inducer. I am thrilled to death with the way my truck pulls, and usually finish in the middle of the pack. (My association sees a turn out of around 30 trucks in this class. ) The frustrating part is that I am usually about 6 to 8 feet from placing. I am running out of things to try with my combination. Other than what I have listed in my signature, I run 2nd gear on the high side with short (265) all terrain tires. My hitch is mounted 8 inches forward of stock. I run down the track at about 21. 2 mph(actual measured ground speed) I need some help stepping outside and looking in. When the spikes go in the ground, I have enough power to spin on most tracks. I killed it on one hard packed track. I ran on a hard packed track last night, but spun out at the end. I think it is probably due to the low end benefit of the Smarty. I didn't have it on the other track. I have only two hooks that were sub 300ft. runs. My question is what now? Bigger injectors? My brain is getting tired. I'll also mention that I am using the fuel up. I only smoke at the beginning and at the end when I bog. The middle is a gray mist. Money is no object (Well it is, but let's pretend for a while):-laf
Let me hear what the masses think.
