Hello all,
It has been a long time since I have posted. The green monster is on light duty these days as it slowly looses the battle with rust. Nevertheless it has always started despite the daylight reaching further and further into the body.
So, I parked it for a few weeks in the cold this winter. I was not surprised it would not start right off on a bitter cold day.
I did the 911 treatment to the fuel and topped off the charge to the fairly new batteries.
The horn did heat up so I know the heaters are working.
No luck but I could see pressure changes from the lift pump when the filter dump valve was slightly open.
I eventually plugged in the truck block heater and tried again (always several times).
No luck despite a few weak coughs
Today I replaced the fuel filter. After replacing the filter I eventually reached the point of some strong rumbling while the starter is cranking but never more than perhaps a second or two after the starter is disengaged.
What am I missing in this pursuit? It is up into the 30's today and I really want to get the beast out of the yard before the snow closes in.
Any thoughts??
Any thoughts??
