The part #of thepre-filter housing
2 year anniversary for my '00
Checking fuel pressure
Does anyone know the part # ,Cummins or Mopar ,of the pre-filter housing?
I suspect I’ve overtorqued mine,’cause there was a leak through the rubber seal. I took it apart and this seal was OK,only stiff due to the ambient temperature of some -10 degree C. I have the habit to overtorque everything since the childhood. And now I’ll need a new one,problems and expenses,unfortunatelly I’m in Europe and here every part for my beloved rig is hard to get…
Thanks for your responses!
Werner
MOPAR only sells as a unit (Heater/casing/strainer/etc) 4762067.
Cummins part number is 3847102 and they don't part it out either.
New gaskets are fleetguard 383418500-S (oring) and 3834185-S (square edged gasket)
Not so. Individual gaskets and parts for the prefilter assembly are not available, but a prefilter repair kit is from the dealer. Part# 04762962. It consists of a strainer screen,gasket for the sediment bulb and a small pressed steel nut. :p
I'd try replacing the seal first, but don't over-torque it next time (I have that habit to :) )
Midnite is correct (not sure about the part number though). You can get a Fleetguard prefilter rebuild kit for ~$8 from a Cummins shop.
