2nd Gen Non-Engine/Transmission The promised eSwitch
For those wondering about the electronic switch (backuplights, washer heater, etc) that I mentioned and promised before. It is HERE. This is the updated version using a common computer CMOS chip, a 4049 called a Hex Buffer (they also make a great distortion pedal for guitar!). This switch allows you to push on/push off or it will reset to off when power is deprived (key off). Each switch utilizes 3 of the 6 buffers and 8 outboard components (11 counting the voltage regulator in the upper left corner). Thus if you think you are seeing double—you are! Two switches from one chip. I would recommend including the regulator- don't count of the truck's charging system to stay within safe limits for a digital device
Any chance you have the pictures hosted where they can be viewed at full size?
If not could you send me it directly? tjkoprevich at yahoo dot com
Thanks
