The Rev B TSB
anyone have a programmer or box on a 6.7?
What happened to Adam??
I thought I saw a recommendation to have the reprogram occur at Lynnwood Dodge, in the Seattle, Washington area. Any experience that anyone can share? Thank you.
I took mine in this morning to enable the high idle feature and asked about rev b one more time. This time they recommended doing it even though I have not had any problems. It took about 20 minutes. Service writer said they are also having alot of problems with trucks not starting, then not have any codes. Mine has done this 3 times but eventually started without having to be towed to dealer. Anyone having this problem? Maybe the wrong place to ask but its fresh on my mind since it happened about 2 hours ago.
Mine did not start a few times when I first got the truck
I found that removing the key and trying again fixed it each time.
I read that others did this and had the same results. After I had the first flash done which was rev A the problem has not come back
I don't know if this issue was taken care of by the flash or not.
I had mine done on Saturday. The dealer claimed they put the latest flash from Dodge. Only noticable difference: truck seems quiter. Never had any problems through 3k miles.
