The tingamajig
INTERIOR PAINT
PRESSURE PLATE FAILURE
The rod that attaches to the front passanger 4X4 axle then attaches to the driver frame with a ball joint has about 2"-3" of give. #ad
I'm not front end inclined so how much is to much and is the ball joint end replacable or do you have to buy the hole rod??
Thanks
Mac
95 Ram 2500 Auto Std Cab, Cat & Muffler Fell off, 125,000 miles.
Bombed-to-be!
If it's a ball joint, that's way too much give. Sounds like the panhard rod. It keeps the whole marianne from going right to left. Ck with the Pep Boys, Allied & other parts houses 1st, before the dealer.
Money Sink - 96, 5 speed, Injectors, 280/685 & AFC housing slid.
4" CAT back & CATless, 4" chrome turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Monicas silencer ring removed, Exhaust brake, Mag-Hytec, 3:54, 235s.
HX35s days are numbered, HX40-16 is here.
Un-Bombed = Boring
RCMC,for sure trackbar or panhard rod(same thing)Book says amount of allowable play is in the hundredths of an inch. Napa is good, $169 for lifetime warrenty,you will have to replace it again and again. I aways called these things stabilizer bars as do most parts houses I've dealt with,I think Dodge may be the only one to call it a trackbar.
Missouri, It drives ok dosen't wander as much as I would think. But A soon as some funds come I think I'll get a new one. Don't want to be haulin down the road and watch the front end slide out #ad
that probably wouldn't be a good thing.
Thanks for all the help
Mac
