I learned today that my sssstststudder may be uncurable
I also learned something today about the ecm and its "fueling states"
turns out the dodge program is set up to run in the "cruise control state" when just maintaining speed ,even with the pedal
then converts to the" continuous shift speed state" as soon as you give her the juice
I dont know exactly what that all means but
it appears that my stumble and shake and hesitation is taking place when the ecm makes that transition
which it makes continuously when Im loaded and holding speed at 58 - 60 mph
the cummins tech couldnt understand why it was running this way but theres nothing he can do about it anyway
I do have a used ecm on its way but I am affraid it will probably do the same as this one because the program is the same
this is the only thing we can come up with because Ive either replaced , tested , reprogrammed everything else that could possibly be causing this ( Ive spent a lot of loot)
I thank all those who have helped me with this issue along the way (too many people to list)
after this, I am all done spending money on this junk pile until I can afford to do a p-pump conversion
I feel that is the only sure fire way to fix it
going to the mechanical side dudes
dont worry I wont trade it off so someone else can deal with it
i should be able to sell enough good parts to help pay for the conversion
