I just came back home from the Int'l Workboat Show in New Orleans, LA. One of the other booths there was ATP (Calif. ), which manufactures thermal blankets for exhausts, manifolds, turbos, etc. They had some special items for sale that were specifically made for the Dodge Ram's Cummins engines. The man I spoke with there, Ed Thompson, told me that keeping the heat in the exhaust manifold and turbo would help the efficiency. I can understand how this would help reduce noise and underhood temperatures, but it seems that this would cause a lot of heat retention in places where it would not be helpful: the turbo bearing, for one.
Also at the show was a rather large floor display of several Cummins Marine engines. I noticed that these engines had similar covers on the turbos, and asked one of the Reps about them. He said that the covers were for fire safety to prevent oil or fuel spray/leaks from igniting on contact with a hot surface. He also remarked that this type of thermal insulation would lengthen the required cool-down time since more heat would be retained in the turbo bearing area. The Cummins Marine engines counter this effect with an oil bath beneath the bearing that allows a splash washer to pick up and renew cool oil in the still-spinning bearing upon shut-down. I don't think we have that on our Cummins, regardless of year.
Who has used these blankets, and what kind of effect do they have on performance and engine efficiency? The search I did about them returned results mainly aimed at noise reduction. I figured that much, but wanted to know whether the ATP guy or the Cummins Marine guy was more "on track".
