Engine/Transmission (1998.5 - 2002) Thermocouple instillation
2nd Gen Non-Engine/Transmission Bilstein Shock installation
Engine/Transmission (1994 - 1998) Which Injectors?
Can I get away without taking the turbo off to drill and tap the hole in the manifold?I can use a vacuum to get the chips out and also some grease on the drill and tap. Would save me some work. Thanks
the method you descibed worked for me twice. i couldnt handle the heat with the truck running.
I did it the way that you described, but got a magnetic screw driver [pullout magnet in tip] & put it down in the hole. It worked great!
