I need advise, I have a 98 12V that needs a thermostat. I checked every parts store in my area and no one had it in stock or said it was the same as a 360 gasser?!?
Finally found one, Stant p/n 14248. Is this correct? I'm a lot unsure. Also got the big seal, but is there another seal? Are they reuseable?
I have searched past posts but only became confused. Which stat to use? Should I use the Stant or get one from the dealer? The way it sounds I should also have a drain cock handy. Maybe I should just get the stat form the dealer as long as I'm there? I really dont want the Stant to stick like others have had troubles with.
Anything you guys can add?
