Matt42
Yesterday, while southbound out of Camp Verde, Arizona up the long grade, my truck heated up to the far end of the normal range. I was pulling a 6K lb TT, and it was only 95 outside. Not even hot. I couldn't hear the fan clutch kick on until I headed down the other side, toward the garlic farm. I was maintaining 55-60 mph in 4th gear. Once the fan kicked on, the temperature dropped to normal, and stayed that way until I got home, and the clutch seemed to cycle normally.
I had gone the other way, up the Black Canyon grade at 108 the prior week, and the coolant temperature barely cracked midrange. I kept EGTs under 1000 both ways.
I figure it could be a sticky thermostat that didn't feed enough coolant into the radiator to heat the fan clutch spring, or a lazy fan clutch. Any thoughts? The thermostat is 2 years old, and a Cummins. The fan clutch is OEM, with 66K miles on it.
Is the fan clutch a Cummins or a MoPar part?
cheers.
cheers.
