Revisiting. Had a cold snap earlier this month and put on the winter-front. Warmed up to the 50s-60s and took it back off. A few days later, I got “check engine” light and the corresponding code was “too cold”. Cleared code and replaced the “bra”. Temps back to 200-ish.Seems pretty unanimous. 200 it is. ![]()
Something doesn’t sound right. The winter front is not supposed to be used at temps that warm, you may have another issue.
That’s my guess, but probably only partially stuck open.Maybe a thermostat thats stuck open?? …what else could it be ??
Either way it needs to be replaced if it is failing.
Well, I’d like to have told you the code, but, it didn’t store as a “permanent”. T-stat does seem to be cycling, though, so I wonder if it’s beginning to fail, or if the corresponding sensor is going bad. I left one little bra hole open when it was warmer, and still not getting, and have seen it as high as 220, then cycled back down to appx 200-205.
