Just finished doing the KDP fix and a new seal. Had the radiator cleaned and added some "water wetter" to the coolant. I put a new Cummins thermostat in last fall and it was working fine.
Since I put the truck back together, the temp doesn't get up to normal, stays at the bottom mark. Not sure why. My question is - when the thermostat fails in our trucks, does it fail to the open position as a fail safe against overheating? I'm wondering if there may be some crap in it from disturbing the system or if it failed. Guess I'll order another one, seems to be a little soon for a failure of the thermostat.
Truck is turned up and smokes pretty good till the temp gets up to normal, need to get this fixed.
