I've changed coolant, thermostat, twice and have used Stant one in 190* and one in 180* so slight was the difference it wasn't worth the worry (because I didn't worry) pulled heavy and long ( but not as heavy and long ) as the super mini trucker and HAVE YET TO HAVE ANY PROBLEMS
Truth be known there is probably only 3 companies that have the Chinese make them, and just stamp a different name on the box & part
On these engines with electronically controlled fans (03+) it is not a good idea to run a cooler, or warmer, thermostat than the OEM thermostat. The fan is programmed around coolant temp and with a 180° thermostat you don't get fan operation until you are above the max allowable temp for that thermostat which is 212°.
Not going to doubt what you say, but have yet to see my temp gauge get over 200 pulling a grade with a load (im sure not as heavy as super mini trucker) but maybe mine is as different as the guys that get INCREDIBLE FUEL MILAGE only my temps don't go high?
