TEMPERATURE RATINGS
Just wondering, are the t-stats for our Cummins available in different heat ranges like the gassers? You know, some are rated to open at 165 degrees, some at 180, others at 190, etc. I'd like to swap mine to end the fluctuation, but I don't want to end up at a lower temperature than what I have, if anything, I want to go higher. If the gauge on the dash is relatively accurate, my engine never gets above about 170-180 degrees. I usually drive pretty easy, unloaded, not towing. But even when I go down the interstate at about 80 mph, I never get to 190 degrees.
If so, any idea what part numbers correspond to the different temperatures?
I'd like to get it to run a little warmer if possible, just because I was told it would possibly help increase fuel mileage if the engine ran warmer. Any truth to this?
Thanks in advance!
