Archived They say I need a new transmission!!!
Archived Transmission slipping
Archived Turbo not working?????
Hello, My husband posted several days ago in the 2nd gen transmission forum (whatever it's called) about our problem, but since then we've gone downhill fast.
'96 3500 dually 4WD automatic.
THE SYMPTOMS THIS WEEK:
first the transmission slipped a few times - once on the highway, but more when starting from a stop or near stop. The truck 'knew' it was in drive (would creep forward if foot taken off brake), as opposed to totally disengaged (as if sitting there in neutral) but would still slip and then finally catch and jerk forward, despite my trying to take off gently. We made the appointment with our Five-Stinkin'-Star dealer for diagnostics.
While I was driving the 45 minutes to the dealer, the transmission slipped almost everytime I had to start up from a stop, and then on the highway it would not shift from 2nd to 3rd. I was going around 60 mph at 2500 rpm. The transmission fluid temp never went above 180 through all of this. I checked the fluid level (truck hot, running in neutral) and actually the level was somewhat high - just above the second 'crimp' in the stick - perhaps 3/4 inch above the hatchmarked 'ideal' level.
The dealer just called, saying that they did a pressure test, and he said that the seals are shot, so we need a new (rebuilt) transmission, or to rebuild the one we have.
THE HISTORY:
the truck has 115,600 miles on it. We've had it since 53000. Regular servicing on the transmission, including the bands adjusted/fluids changed at 93,000. Then last year, at 103,000 we had this problem with not shifting from 2nd to 3rd, so had the servicing done again, including cleaning solonoids, adjusting bands, changing fluid. It seemed to work fine after that. Perhaps 1/2 of our miles are with a light horse trailer, usually with one horse - well within the weight limits for towing. I am VERY careful and gentle when hauling - no fast taking off or anything rough - because I don't want to throw the horse around.
THE QUESTIONS:
Well, I guess the questions are obvious.
1. do we take this guy's word for it, and empty our pockets into his without getting a second opinion?
2. his proposals were for either a rebuilt transmission from Chrysler (installed for $2650) or having our transmission rebuilt in the shop with a Chrysler kit (about $1500) assuming he doesn't find anything else wrong with it.
The factory rebuilt one has a 3 yr/36000 warranty. Having ours rebuilt has no warranty. Also, having ours rebuilt and thinking we're saving $1000 doesn't guarantee that it will solve our problem - what if something else is wrong with our transmission that isn't fixed in the rebuild? The guy enumerated other things that he could find once he gets going - and it seemed to add up to a lot of money fast. Does anyone ever come out ahead going that route (other than the guy servicing it, of course)?
3. are there other things that should be done/checked first, or is that just risking totally destroying what's left of our transmission while we dilly dally around, adjusting, changing or testing this or that?
4. Is there someone who is a miracle-worker with transmissions and trustworthy in the Madison, WI area (or within reasonable driving distance) who would be able to either give a second opinion or do the complete job?????
WHAT SHOULD WE DO?????
Our daughter shows her horses, and we finally got to the show season, so there is a massive flood of tears here as we need to cancel out on activities until the truck is back in commission.
OK, my husband just told me that anyone who reads this entire post is a Saint, so I'm going to post this without further babbling.
Thank you so very much for any assistance.
Katy (and Steve) :{:{
Sounds to me like the transmission is toast. I would have them install the new (rebuilt) one from DC and not have them rebuild the old one. Or call one of the after market trans shops like DTT, Suncoast, ATS or the like. Price wise it will be more to get one from someone else but it will last a lot longer than the OE one.
If you can don't mess with a half done rebuild. go oem or aftrmarket, he could open it up and cost alot more than just replacing plus you get the 3\36 protection.
my . 02 after many slush boxes.
Katy, sorry about your problems. My advice is to bite the bullet and get a good transmission rebuild from DTT ( Diesel Transmissions Tech) You will be so much happier than you would be with a new original Dodge transmission. It will cost a little more but believe me, the improvement in performance will be worth it. You will get a lot of advice as to which transmission is best - most any are better than the OEM.
Call DTT toll free 1 866 504 4002 they will give you good advice and probably have an installer near you.
I read your entire post.
Tom
thanks - more ?'s going to other forum
:( OK, so I'm really sad, though very appreciative of your instantaneous replies. You are ALL saints.
I had really hoped that somebody would say, "oh yeah, my truck does that - makes the service guy think that it needs a new transmission, when all it needs is a new $12. 00 part to get it back on the road. "
OK, so now that I am facing reality that I won't have my truck back soon - no longer in denial - I guess I have more, non-911 questions that I'll post in the other forum. I've left a message on DTT's answering machine - and I'll do more checking around tomorrow during business hours.
Thanks again - you guys are a great resource - we appreciate it so much.
And no, MMclain, my mom didn't drive a Cummins, but my daughter's mother does!!! ;) I guess I should have gone with the 5-speed like your mom did. :(
Katy
Just a guess,it sounds like your 3rd gear seals are bad. A long or no 2-3 is commonly caused by that. With your mileage a full rebuild/exchange unit is the only way to go.
Aftermarket is the only way I'd go. ATS or DTT or someone else in that category. They will provide you with a transmission that will be tailored to your needs and will outlive and drive better than a stock 47RE ever could.
Good luck.
Kathy,
If you lived near me I would probably let you use my truck. :(
I agree with everyone else - go with an aftermarket transmission don't waste money on a stock rebuild etc. esp. if you plan on keeping the truck.
You own a great truck and the weakest link just gave way, if you put a quality transmission in her you'll be more than happy. Contact the major aftermarket transmission companies - (SunCoast, DTT. ATS. etc) and find an authorized installer close to your home, that way you will have service and warranty near at hand and go that route. You won't regret it.
Best of luck.
Katy and Steve. . may I suggets you take a moment and fill out your truck sig. info so others can look what ya got to help ya out better... maybe a town near you also for referance to help locate a supplier [I know I don't have that in mine... been here since dirt so most know I live by Yosemite :) ]
May Sound Crazy But . . . . .
We're presently in the process of re-financing our home and getting some extra $ to boot. I WISH I had transmission problems so I can finally get rid of the stocker and start bombing under the hood.
I'm sure everyone is steering you all in the correct direction - go for the specially prepped for our 5. 9b's transmission and it will out perform and out last the stocker. good luck.
