Not that anyone is nearly as inept as I am. But if you are doing a twins install on a 24 valve motor and for some reason you decide that the little plug that covers the second oil drain hole just has to go for a swim in the oil pan. I discovered that if you remove the pan bolts, lower it to the cross member,push it forward and then turn it so the front of the pan is to the pass side and the rear is to the drivers side, you can reach inside with your right arm and get it. I am not a small person and I don't have skinny arms. I tried every lure in my tackle box and I could not get it to bite. So I figured it was time to try live bait.
RonA
RonA
