A few months ago, I put a 2" SuperLift leveling kit on my '03 Ram 2500. This amounted to swapping out the OEM coil springs for taller ones (bump stops too). After I did that I heard a thunk in what I believe is the driver's side suspension when turning at low speeds (like when I pull out of my driveway). I looked high and low and could not isolate the problem. I had the mechanic at the place I get my tires check the front end and he confirmed everything was tight and nothing was damaged. Then the bump went away (figured it was something trying to seat), but my front shocks failed. I had Edelbrock IAS Performers and confirmed with Edelbrock that the shocks I had were ONLY designed for OEM height and Edelbrock did not make IAS Performers for Rams with 2" lifts. This was my own stupid fault for not taking the shocks into consideration when I put the leveling kit in. However, I just replaced the failed Edelbrocks with Bilstein 5100's designed for a 2" inch lift. My truck drives a ton better, but now the thunk is back. #@$%! Anybody have any suggestions as to what this might be? Thanks!
