Things to look for when transmission is out.
High Pressure Fuel Pump Takes Dump.
Fleece Coolant Bypass Kit Doesn't Bolt Up
I will have my transmission out of my truck here in about an hour for a clutch replacement. I might do the rear main seal since it has over 400k on it. Anything else I should be taking a look at while I have it out?
Oil pan gasket and cam seal as well. 400K is a good bit, it'd be a shame if you get it back in for either one of them to start leaking from age.
Motor mounts as well if they're blown.
